Remove the negative battery cable from battery for at least 10 seconds. 2 minutes to be safe and reconnect cable. I clear my codes this way when the problem has been fixed.
I have an 8FDU30 Toyota with a wrench light displayed on dash. I assume it has a code but on a Toyota Diesel I do not know how to access the code or get it displayed. A wrench light doesn't tell me much.
You may still have a reoccurring hard code.
Yes. Tried jumping the Tc and E1 pins at the DLC with the negative cable disconnected and then reconnecting it and turning the key on and pressing the accelerator pedal 5 times.
Have you tried disconnecting the battery for a few minutes? This will reset most trucks.
