RD POWER CHARGER FAULT CODES
HI ALL
DOES ANYBODY HAVE THE FAULT CODES FOR AN RD 90 CHARGER
  • Posted 17 May 2012 02:04
  • By keith_t
  • joined 3 Nov'09 - 100 messages
  • essex, United Kingdom
Showing items 1 - 18 of 18 results.
C8 is indicates a current sensing failure, which usually indicates a fault within the controller, which is by now is unlikely for a replacement to be sourced. However its well worth looking at the current sensing leads attached to the current sensing shunt mounted on the front of the main rectifier, (it looks a bit like an oversized razor blade). Also have a look at all the bolted shunt mountings, any signs of loose connections and / or over-heating ? If so file clean and, or replace.
  • Posted 23 Dec 2023 08:37
  • By Trevor_Crown
  • joined 23 Dec'23 - 2 messages
  • United Kingdom
T E Crown
Manuals are hard to come by. Tell me your problem and I can most possibly help you. TC ex designer of original RD Power
  • Posted 23 Dec 2023 08:13
  • By Trevor_Crown
  • United Kingdom
T E Crown
Hi All,
Looking at a very old RD100 controller PCB.
Anyone still got a RD100 tech manual or schematic they could email me?
Many thanks.
  • Posted 20 Aug 2020 02:46
  • Modified 20 Aug 2020 02:47 by poster
  • By john11
  • joined 20 Aug'20 - 1 message
  • China
I keep getting C8, does this mean anything to anyone please. Cheers in advance. Danny
  • Posted 3 Jan 2018 06:25
  • By DannyW
  • joined 3 Jan'18 - 1 message
  • aaaaaaaaaaaa, United Kingdom
Could You send me manual witch falut codes for RD100?
  • Posted 24 Oct 2017 19:41
  • By tomasz_r
  • joined 24 Oct'17 - 1 message
  • Slaskie, Poland
Hello,
I´m new here- I have also trouble with the charger RD100
It shows me DC Fault and b4
Any idea where I have to search the fault ?
Maybe i can get a copy of the manual too ?
ov at vabo dot com
Thank you all
Many greetings from the rainy germany
Oliver
  • Posted 18 Jun 2016 02:13
  • By eljoty
  • joined 18 Jun'16 - 1 message
  • Germany, Germany
hi
could i please gert a copy of the manual for rd100 charger
Thanks in advance
chrisfreeman dot welding at gmail dot com
  • Posted 28 Jan 2016 03:31
  • By freemanwelding
  • joined 18 Feb'14 - 1 message
  • Gloucestershire, United Kingdom
HI ALL
DOES ANYBODY HAVE THE FAULT CODES FOR AN RD 100 CHARGER / manaul ?
  • Posted 29 Apr 2015 00:00
  • By rene_v
  • joined 28 Apr'15 - 1 message
  • N Braband, Netherlands
Same charger different fault code!! c8. seem to be able to clear it by powereing down and restarting.
does anyone have a list of fault codes
cheers
rids
  • Posted 4 Apr 2014 17:00
  • By rids
  • joined 31 Jan'14 - 5 messages
  • tyne and wear, United Kingdom
traced fault to a bad connection behind centre fuse causing intermittent fault.
thanks for all help, really usefull.
cheers
rids
  • Posted 7 Feb 2014 02:07
  • By rids
thats excellent thanks. will not get back to this job untill thursday. will keep you posted of results
cheers
  • Posted 1 Feb 2014 17:24
  • By rids
Hi, Rids,
That code refer,s to a DC power fault,
1 Check fuse 2 on the inner control panel it's the middle fuse rated at 500 ma.
2 check for mains voltage across primary coil, if no voltage present check for ac voltage at the ac terminals of contactor coil, if you have volts replace coil if not replace controller.
3 if you had ac volts at primary winding, check for ac volts across secondary winding they should be opprox 2.5v x no of cells,still ac. If no suspect transformer winding yes move on to 4.
4 check for same voltage at ac terminals of rectifier if yes replace rectifier if no check associated wiring.
If your not an experienced electrician My advice is don't go inside this charger get a charger engineer in to do the work.
  • Posted 1 Feb 2014 02:02
  • By NER045
You really need to buy a DC amp clamp. Testing a charger without one is near impossible went it comes to no current. You might have 75 volts but if your only pushing 60 amps where it should be 180 you cannot know.
Now go get one, if you test and find its low amps check your diodes. That's usually where I look. GL
  • Posted 31 Jan 2014 22:49
  • Modified 31 Jan 2014 22:49 by poster
  • By Rmullis
  • joined 8 Jan'14 - 15 messages
Russell mullis
Atlantic Forklift Services
Charlotte, Nc
Mullis.russell@gmail.com
7042967564
i havn't another truck or battery to try it with! with batteries connected, the charger is pushing out 75volts, with charger disconnected the batteries are holding about 70 volts.
  • Posted 31 Jan 2014 20:48
  • By rids
C3 = No charging current.
I'd be tempted to try another battery on it first if you have another on site to try.
  • Posted 31 Jan 2014 19:17
  • By Forkingabout
  • england, United Kingdom
I'm after the same for a rd 100 charger, I have a c3 fault code and i don't know what it is! charger runs for aprox 15 mins then the cuts out with c3 fault
cheers
rids
  • Posted 31 Jan 2014 02:32
  • By rids
thanks
  • Posted 18 May 2012 06:46
  • By keith_t
check mail
  • Posted 18 May 2012 06:41
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
UN Forklift FD35T
Terberg YT220
