RC5530C-30 Error Code 218
Hi guys I'm getting a 218 error code on this machine when you attempt to travel, lift, or side shift. Cycle the key off and back on, but when you attempt to move it'll go a couple of feet and quit again. Or if you try to lift it begins to lift then the pump kind of revs up and quits and the code pops up. Any help would be great. Thanks!
  • Posted 11 Mar 2022 13:41
  • By Vegastime1
  • joined 13 Dec'18 - 12 messages
did you ever figure it out.. i have one doing the same thing
  • Posted 26 Jan 2026 20:25
  • By kingkuality
  • joined 21 May'17 - 63 messages
Check pump contactor fuse for voltage drop, if not that pull pump and inspect splines.
  • Posted 22 Jun 2022 15:35
  • By Ratm
  • joined 21 Jun'19 - 17 messages
Stoney
The dot above a lowercase "i" or "j" is called a tittle.
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
