Raymond R40TT no aux. function
have a raymond that drive and lift, but no s/s, tilt or reach.
no codes showing.
contactor closes for fwd/rev, same contactor won't close for other functions.
followed procedure and figured that VFC card no good, put a new one in still the same.
is the next thing the joystick?
  • Posted 22 Dec 2009 05:12
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
yes. changed the line fuse.
thank you.
  • Posted 15 Jan 2010 07:16
  • By hellokitty
have you fixed it yet? If not, try the fuse in the top of the line filter (its a slo-blo fuse). The line filter is under the large access cover on top and at aprox. 11:00 o'clock position from the control handle. There is a small pastic grey screw cap and underneath is the fuse. When these blow, you will lose all aux functions, but it will travel and lift. If the fuse is good check the Over the mast cable at different positions, could be a bad spot in cable. Last look at control handle.
  • Posted 15 Jan 2010 07:04
  • By just_m
  • joined 13 Jan'10 - 9 messages
check your 18/6 overhead cable.
  • Posted 24 Dec 2009 22:05
  • By ron_p
  • joined 4 Mar'05 - 11 messages
  • Illinois, United States
Yes they are.
Did anyone change the settings in the program?
Rereading your post you have no pump turn on. That is suggestive of a broken wire
If you can access the SW (nad you will need to if changing the handle) there is a test for those functions in the control handle.
  • Posted 22 Dec 2009 10:45
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
it's a Raymond EASI R40TT, EZ-A-00-16178
going to change the handle tomorrow to see what happens. very expensive.
  • Posted 22 Dec 2009 09:07
  • By hellokitty
you didnt list the SN, complete model #
Is this a Reach truck? EasiR40TT or a dock truck? R40?
Sorry very different beasts for the issue
Handle is an issue, can you access the Superword?
If a reach truck look at the cable in the pentagraph. They are notorious for causing issues and failing
  • Posted 22 Dec 2009 08:43
  • By JonG
  • United States
Morooka MFD20
Taylor TT300
USD98,500
Saratoga, United States
East Syracuse, United States
Columbia, SC, United States
F. Uchiyama
