Raymond order pickers
Has anyone heard that the new order pickers by Raymond will not lower with the emergency lowering valve?
  • Posted 17 Aug 2007 10:59
  • By Chrissa
  • joined 29 Jul'05 - 10 messages
  • Queensland, Australia
would you have a parts manual for a Raymond 152OPC30TT?
thanks
  • Posted 14 Feb 2011 13:00
  • By rplpallets
  • joined 8 Jan'09 - 17 messages
  • Wisconsin, United States
not a problem!
  • Posted 9 Jan 2009 09:59
  • By E_lift
  • joined 9 Dec'08 - 15 messages
Thanks for your diligence I just went through my service bulletins & found it. I am embarrassed that it got by me I am typically pretty good at implementing updates from the service bulletins.
I will be sure to pass the word around our shop too.
  • Posted 9 Jan 2009 09:42
  • By pappy_f
  • joined 20 Apr'07 - 16 messages
ok after looking at the hydraulic schematic, electrical schematic, manual and service bullitens.
the key has to be off or the battery has to be unplugged in order for the e-lower to work. when on (even on auto off) the prop valve (which is normally open) is receiving voltage keeping it closed. so when turning the e-lower/L/H solenoid **** it will do nothing.
If you look up RSB OPR-07-001 it has a newer software that fixes this and will allow the truck to be lowered when ever.
  • Posted 8 Jan 2009 23:53
  • By E_lift
i have to double check on this for the reason why. there is a logical reason why.
But as I stated above this is only for the 5200 not the 5400-5600 orderpickers.
  • Posted 8 Jan 2009 08:54
  • By E_lift
I have worked on several 5200 orderpickers this week.
You need to step on the deadman for the emer. lower to work! If the truck times out you will need to rekey the truck!
I have a question to add.
what do you do if your operator is incapacitated! How do you get him or her down. Assume no tech on site & no other orderpickers in the building!
  • Posted 8 Jan 2009 07:48
  • By pappy_f
the 5400 and the 5600 model raymonds will lower at any time using the emergency lower. The 5200 I think is the one that doesnt with the single speed lift as they dont go as high as the othe models. I will double check
  • Posted 8 Jan 2009 04:14
  • By E_lift
On the models with single speed lift the carriage will not come down with the key off. These are the ones with the lowering valve on the lowering solenoid.
  • Posted 21 Feb 2008 08:39
  • By dan_d
  • joined 7 Feb'08 - 7 messages
hi,Chrissa:
Lower valve is important part of the products.
And Ray is famous brand, if chage, she would notice the clients.
This is what i do.
Service will change your business: )
Moon
  • Posted 17 Jan 2008 16:59
  • By Moon
  • joined 8 Jan'08 - 45 messages
  • NingBo, China
Chrissa you are correct! the 5000 series pickers will not lower by simply opening the emergency lower valve, you need to step on the deadman pedal. Further if the picker is set to time out you will need to rekey the truck to get it to lower. I have questioned the wisdom of this myself!
  • Posted 23 Nov 2007 00:40
  • By pappy_f
Hi Chrissa:
Specific videos on the truck can be found here:
raymond-forklifts.com/Orderpicker.html
  • Posted 21 Sep 2007 11:04
  • Modified 17 Mar 2008 09:27 by poster
  • By Solutions
  • joined 22 Jul'07 - 10 messages
http://www.raymondhandlingsolutions.com
US confidence index rises sharply Washington, DC, United States
Hawker Powersource, Inc.
Bolzoni SpA (Group HQ)
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Combilift Ltd
Evansville, IN, United States
St. Louis, MO, United States
Daleville, IN, United States
Uxbridge, Canada
