Raymond Lift G3 and G4 codes
G3 and G4 codes, can work dead man switch several times and then it will tram but no steer
  • Posted 13 Aug 2013 07:59
  • Discussion started by JC41
  • West Virginia, United States
Good day. I have an ERC 16 model. How can I replace the damper?
hikder
Hi thanks fort the help I find the pedal assembly is bent and remplace it and the code go away
  • Posted 28 Nov 2023 10:14
  • Reply by armando_g
grgarryciencia@aol.com
I believe this is an order picker
  • Posted 30 Sep 2013 23:59
  • Reply by 1sharpdog
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
What is the Model? ser #? Electric steer?
G 4 on a 7400 is a steer card fault
G3 is Prox sensor at drive unit. Didnt see it
The prox needs a 020 thou gap. if the steel ring is hitting the prox, the radial rings are gone. look under truck at drive unit, do you see steel on steel wear marks? drive truck with door off, does the drive motor rock back and forth when you plug?
This all indicates worn radial rings. Keep driving it with worn rings and you score a hat trick....steer motor blown, steer card and radial rings
  • Posted 30 Sep 2013 12:58
  • Reply by EasiTek
G3, G4 is either the steer tiller pot behind steering wheel or encoder at steer drive ring next to steer motor.
  • Posted 29 Sep 2013 13:23
David Sharp
edition #1229 - 8 May 2025
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
