Raymond 740-R35TT:
Raymond error code
Unit lost control yoistick Didn't work brake didn't respond error message on the display 5m can someone help on what is means
Thank you
  • Posted 6 Nov 2015 05:25
  • Discussion started by GUANAJUATO
  • Illinois, United States
first thing you do is look ay fuse relay card. Numero uno culprit for intermittant cut outs, codes 5G,5J, 5M Remove the second relay from the left and look carefully at botton female slots. They may be fried, causing loss of current to VM. Remove the other relays and compare the female connectors to each other. They should be all tight together. Any discoloration or gap between pins indicates a new fuse card is needed. The relay will often appear burned as well. And always check for shorts to frame, battery voltage leak with an ampmeter. If the pins are just starting to get bad on the board, and the relay is fried, you can, as a temp repair, use the fourth relay on right and swap with the second one (after you cleaned the female pins) All your trucks will eventually fry the relay boards>>>
  • Posted 6 Nov 2015 09:47
  • Reply by EasiTek
Enforcer FD50T-MMA
Taylor T650L
edition #1228 - 1 May 2025
