Raymond EASi ET-B - 95 0148
Trying to find Brake assy - Number on Brake assy SAH-600 5169-02
Can anyone cross to a raymond # ?
  • Posted 8 Mar 2018 06:30
  • Modified 8 Mar 2018 06:30 by poster
  • Discussion started by Prentice
Hey Stam Hope all is well.
Did a bit of research - 2 styles - Metal disk with upper and lower brake pads(My style ) and assuming updated version with fiber disk flat upper/lower plate - 6 inch diameter for ET-B
- There is also a 7.5 and 8 inch version
I have tried to reseal these units in the past and found most times the housing was pitted and worn where the seals ride.
I normally install a new unit to save any future headaches
So...found Part # 870-900-001 (Update) would fit nicely
Thanks for the feed back :) Enjoy the day
  • Posted 13 Mar 2018 00:09
  • Reply by Prentice
They can be rebuilt.
Aztec will sell friction plates and rotors.
Tvh sells the seals for the slave.
The springs rarely fail.
I believe you have a 24 volt truck so you have the "small" brake.
I don't have a parts book at hand.. if you still need the number reply and I'll get back to you Monday.
  • Posted 10 Mar 2018 20:17
  • Reply by stam
edition #1229 - 8 May 2025
