Raymond Dash Code I02 In
Unit is a EASI R30TT, unit and all functions running OK, need to know what this code is and how to remove it to keep customer happy. Thanks
  • Posted 1 Jan 2012 09:41
  • By pubs645
  • joined 1 Jan'12 - 3 messages
Yes I cleared the active maintenance code with the superword and then performed maintenace on unit to discover that the static strap was torn off, since this unit runs off and on wooden floors static is a problem so your comment on your last post makes sense, will put new strap on and put unit back into service to see what happens. Thanks
  • Posted 9 Jan 2012 08:38
  • By pubs645
It's in active maintenance. Test i 02 is for the first speed mast switch. It shows on the display while cyou drive if the mast is un-nested. Do you have Superword or just Password? You have to clear any active maintenance tests. You may have entered this unintentionaly or there is a system card failure, VFC and firmware failure. Static or shorts to frame, bad battery will ruin these parts.
  • Posted 9 Jan 2012 01:02
  • By EasiTek
Yes I rechecked the dash is indicating "I02 In" but the funny thing is when customer was down for xmas holiday's and returned Monday the code disapeared but came back in 4 hours of use. I'am the only person with the superword. HUH?
  • Posted 5 Jan 2012 10:25
  • By pubs645
That is "input 02" Not a trouble code. Someone left the truck in test mode. You have to get in with superword and clear the test. It's letting you see those values while in use.
Are you sure that is what is on the display?
  • Posted 3 Jan 2012 08:55
  • By EasiTek
ROYPOW
ROYPOW
