RAYMOND Can not enter superword
Easi OPC30TT S/N Easi 94 AJ09982
I was having code 23 replaced the Q1 the truck started up no problems. Then i decided to run learn mode. i got thru the move forward and reverse then went to lift and no beep finally it beeped then went to down no beep at all. so i turned the key off thought i would try again and now i get no bar to enter superword it just shows weight. Tryed differant control handle and get the same thing. now getting code 45 This thing is kicking my butt. Ran learn mode 2 times with no problems before changing Q1 sure could use some ideas!!!
Thanks James
  • Posted 19 Apr 2012 13:48
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
Showing items 1 - 20 of 21 results.
Now in getting FH
The info chip was crrupt, the electronics guy at Malin was very helpful and put new chip that was causing some problems the code 23 was intermittent. have changed the battery with new one ran the test and it shows 37.4
  • Posted 23 Apr 2012 01:29
  • By Parkway
On a code 23, ALWAYS replace Q1 and REC 2, they come in a kit. If you go through SMH, they are like $250 cheaper than a Malin or Raymond dealership. Also made sure your TM modules are still good, if not they have to be replaced as a set.
  • Posted 22 Apr 2012 01:34
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Found bad crimp connection at plug.
Now I can get back to original problem code 23
  • Posted 22 Apr 2012 01:08
  • By Parkway
if these are anything like the ray/cats ohming it out wont help you when installing it, the truck uses voltages not ohms when reading the pot.
The only advantage you will get from ohming it out is to see if the wiper/varistor is defective or not.
Which is helpful but wont get you in the right ballpark when setting the pot so the system can see it in the "right place".
:o)
  • Posted 21 Apr 2012 23:25
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
How many ohm's ?
Should I be reading
  • Posted 21 Apr 2012 13:52
  • By Parkway
Working in now it is bad, there was a bad chip in the card to.
  • Posted 21 Apr 2012 07:41
  • By Parkway
Did you have a chance to ohm out the pot?
  • Posted 21 Apr 2012 07:37
  • By 1sharpdog
Different parkway never worked at any heb's
  • Posted 21 Apr 2012 07:32
  • By Parkway
Is this parkway, as in HEB? I use to work a Malin. Took care of HEB's fleet for a while.
  • Posted 21 Apr 2012 07:28
  • By 1sharpdog
Thanks will let you know it turns out
  • Posted 21 Apr 2012 07:03
  • By Parkway
check the wires termination on the pot, make sure the circuit isnt across the resistor circuit instead of being on the resistor and wiper like its supposed to be. If wired incorrectly it will read wrong. I also know its tight in that area so while checking the wires make sure none are touching each other....
They should be insulated with heatshrink though.
I can tell you this though, if you dropped out of learn mode in the middle of programming you did fubar it up a little bit and it will be a pain to get it back to the normal spot without using the analog test mode to monitor voltage while aligning it.
good luck!
  • Posted 21 Apr 2012 06:28
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Malin is checking the handle now.
Something is really screwed !!
  • Posted 21 Apr 2012 06:18
  • By Parkway
Ohm out the pot, do you have a schematic, i do.
  • Posted 21 Apr 2012 05:47
  • By 1sharpdog
Yes it reads the vr1 checks good
but will not read the vr2 it just stays at 5volts
  • Posted 21 Apr 2012 03:00
  • By Parkway
I am in houston. did you run analog tests for travel and lift pot?
  • Posted 21 Apr 2012 02:34
  • By 1sharpdog
Was not able to enter password
the lines would not come up!
I found a way to get my password entered, via display
Tried runing learn mode for control handle, would not read vr2
The handle is good I know and have a backup
Ran tests for vr1 and vr2 card is not reading vr2
Just reads 5 volts thinking the CCC is bad. What you think??
Where you at in TX ? I'm in DFW Metriplex aera
  • Posted 20 Apr 2012 11:20
  • By Parkway
What password are you using. Am a factory trained raymond tech, I could help.
  • Posted 20 Apr 2012 08:49
  • By 1sharpdog
Replaced VFC and display
Still can't get in
  • Posted 20 Apr 2012 08:08
  • By Parkway
We're is this info stored
and how do I clear it or re set?
  • Posted 20 Apr 2012 04:08
  • By Parkway
Thanks but it did not help
  • Posted 20 Apr 2012 03:09
  • By Parkway
Muncie, IN, United States
