R30E mast cable
I have several R30E and R30F trucks my co-worker and I service. These are 1991 to 1993 models. We need a 20 wire mast cable. The parts book lists a 21 wire cable. Either would work. We have ordered this from the local Hyster dealer. They tell us the factory does not have it and does not know when or if they will get it. Does anyone have a source for this cable?
  • Posted 6 Jun 2007 14:03
  • Modified 6 Jun 2007 14:04 by poster
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
liftdoctor
The original cable was smaller. We measured the pulleys, and they were about an inch wide, so we figured it would work. However it did not. I think part of the problem was the Belden cable was not twisted inside. I think this helps the cable roll over the pulleys better and distributes the tension throughout the wires in the cable. I have some of the cable from the original manufacturer on the truck, and it is working. The cable is much smaller then the width of the pulley. It measures about.600. I think this may also help with not having the cable ride up over the edge of the pulley. I do have about 65 feet of the Belden cable. If anyone wants it, I will sell it cheap.
The OEM cable is called something like Rockbestos Perfect-A-Flex.
  • Posted 29 Jun 2007 09:34
  • Modified 29 Jun 2007 09:37 by poster
  • By Liftdoctor
The Beldin cable's Overall Nominal Diameter is.862 in. ,which I posted in the specs. Did you measure the O.D. of the original cable?
  • Posted 24 Jun 2007 03:31
  • By Truck_Tech
  • United States
If anyone else is reading this, I am sorry to report the Belden cable did not work. It is not twisted inside, is a larger diameter, and runs off the sheave every time we lift. I would need to find bigger sheaves to make the Belden cable work. We did find a source for the cable. It is a electrical supply house called Kirby Risk. The parts dept called the manufacturer which steered us to Kirby Risk. The old cable was painted from one end to the other. After I got the old cable off, I was able to scrape off paint and read the brand name.
  • Posted 23 Jun 2007 07:40
  • By Liftdoctor
Your welcome,Liftdoctor. Glad I could help.
  • Posted 8 Jun 2007 13:19
  • By Truck_Tech
  • United States
Thank you very much. The cable is on order and much less expensive than what Hyster wants for it.
  • Posted 8 Jun 2007 12:44
  • By Liftdoctor
Belden Part# 9429 Portable Cordage - SO Oil-Resistant Rubber Jacket
For more information please
call
1-800-Belden1
Description:
SO oil-resistant rubber jacket, 600V, 60ºC, conductors cabled with fillers, paper tape separator, smooth jacket, UL/CSA listed, color code:
see chart 2 (Tech Info Section).
PHYSICAL CHARACTERISTICS:
CONDUCTOR:
Number of Conductors 20
Total Number of Conductors 20
AWG 16
Stranding 65x34
Conductor Material BC - Bare Copper
Type of Cordage SO
INSULATION:
Insulation Material EPDM - Ethylene Propylene Diene Monomer Rubber
Nom. Insulation Wall Thickness.033 in.
OVERALL CABLING:
Overall Cabling Fillers Jute
Overall Cabling Color Code Chart Black, White, Red, Green, Orange, Blue, White/Black, Red/Black, Green/Black,
Orange/Black, Blue/Black, Black/White, Red/White, Green/White, Blue/White,
Black/Red, White/Red, Orange/Red, Blue/Red, Red/Green
Overall Cabling Separator Material Paper Tape
OUTER SHIELD:
Outer Shield Material Unshielded
OUTER JACKET:
Outer Jacket Material Rubber
Outer Jacket Nominal Wall Thickness.100 in.
OVERALL NOMINAL DIAMETER:
Overall Nominal Diameter.862 in.
MECHANICAL CHARACTERISTICS:
UL Temperature Rating 60°C
Bulk Cable Weight 457.9 lbs/1000 ft.
APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE:
APPLICABLE STANDARDS:
NEC/(UL) Specification SO
CSA Specification SO
EU CE Mark (Y/N) Yes
EU RoHS Compliant (Y/N) Yes
EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004
FLAME TEST:
CSA Flame Test FT2
PLENUM/NON-PLENUM:
Plenum (Y/N) N
ELECTRICAL CHARACTERISTICS:
Max. Operating Voltage - UL 600 V RMS
Dielectric Withstand Voltage 2000 V AC Applied for 1 Min.
Max. Recommended Current 5 Amps per conductor @ 25°C
PUT-UPS AND COLORS:
Item Description Put-Up (ft.) Ship Weight (lbs.) Jacket Color Notes
9429 010100 20 #16 EPDM CPE
100 48.4 BLACK
C
9429 010500 20 #16 EPDM CPE
500 233 BLACK
C
C = CRATE REEL PUT-UP.
Revision Number: 1 Revision Date: 06-17-2005
  • Posted 6 Jun 2007 15:09
  • By Truck_Tech
  • United States
Advance CS7000
Illinois, United States
USD8,000
Morooka MFD20
July 9-10, 2025 - Birmingham, United Kingdom
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
