Proxy sensors not getting power, forward solenoid stuck on
We have a 2022 C6000 combilift. The combi will not change direction or drive. The foward solenoid on the valve bank is constantly on. None of the proxy sensors light up when changing direction on the toggle. When testing on the plc board the proxy sensors do not turn on, but when testing all other functions on the plc board they light up.
  • Posted 16 May 2025 23:40
  • By Nic_Olson
  • joined 16 May'25 - 7 messages
Hi Nic,
Glad you got all sorted.
The technical support is there anytime you need it.
  • Posted 29 May 2025 21:02
  • By Richard_Irwin
  • joined 20 Feb'20 - 85 messages
  • Monaghan, Ireland
Issue solved, #11 fuse was blown and rear 90 degree proxy needed to be replaced
  • Posted 29 May 2025 20:59
  • By Nic_Olson
Hi Nic,
Not sure of the specific issue, but Combilift have a dedicated Technical Team covering North America. If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
The North America Team will be back to you quickly. Hope you get sorted quickly.
  • Posted 29 May 2025 19:58
  • By Richard_Irwin
  • Monaghan, Ireland
UN Forklift FBT18NQZ1
SMV (Konecranes) 4632CC5
