PROBLEM WITH LOAD MOMENT INDICATOR
Good morning dear,
I have Aisle-Master truck fitted with a scale and in the display, I am getting 2 green dots indicating the percentage of the weight on the forks although the truck is not handling any load, Please help.
  • Posted 25 Feb 2021 19:10
  • By Isa_Alderazi
  • joined 25 Feb'21 - 10 messages
  • Bahrain
Isa Alderazi
thank you my dear, i will check the brand and model of the scale and let you know.
  • Posted 1 Mar 2021 02:30
  • By Isa_Alderazi
  • Bahrain
Isa Alderazi
Isa,
zero the scale.
I'm sure combilift may be able to help but the mfg of the scale should have supplied a manual for that scale, if not you can contact them also.
Most scale's have a zero button or in some cases it may require a re-calibration as was suggested which would be included in the operators manual.
Do you have a brand and model number of the scale?
Maybe we can figure this out on here so others will know also :o)
  • Posted 1 Mar 2021 02:25
Hi Isa,
The Combilift team can help you with this, it seems like it needs re-calibration. If you can access to the Combilift web page, scroll to the bottom and select Technical Support or click on the "were online" bit and they will point you in the right direction.
Hope this helps,
Richard
  • Posted 26 Feb 2021 21:57
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
