problem brakes slow velocity
hello,
I have a problem and I can't find the solution. I hope you can help me.
We have a 335/01, when the machine starts to move at low speed when you release the accelerator pedal it brakes abruptly, however if we go at a high speed and you release the pedal the braking is progressive.
The traction motors have been repaired, the gear, braking and regeneration contactors have been changed, without a solution, if the lbc braking is eliminated the machine only reduces the speed due to inertia, but regulates the lbc braking (from 100a) to a little speed brakes dry. has no errors
  • Posted 8 Aug 2024 15:22
  • By jay_ja
  • joined 8 Aug'24 - 2 messages
  • Spain
SMV (Konecranes) 4632CC5
Toyota 8FD45
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Toyota 8FD45
