I Have problem with this Code C0 and F0 do you have some information.
hey rich k. i have some problem in the steering the problem occurs sometimes...i already sent he steering motors for rewinding the problem fix and a couple a week the truck got same problem found a blown fuse replace it nothing happened
I'm hoping for some info thank you for any info about this.
Does it have "on demand" power steering? If so it has a torque sensor on the bottom of the steerig shaft. That sends a signal to an electronic circuit board to turn on the power steering motor.
no error code? Control board is probably the reason.
