Toyota 8FGU32:
Power Adjustment
I've got an 8fgu32 s/n 63427 that runs great but has no power when on an incline (fwd or rev).
I've checked/adjusted the timing but to no avail.
Engine just doesn't seem to have any torque.
  • Posted 8 Mar 2024 15:52
  • Discussion started by Kevin_Linn
  • Iowa, United States
Check your inch pedal cable. It shouldn't Be tight , allow a 1/4" pedal movement before cable pulls. Check mixer gaskets. Check TA adjustment and 02 sensor readings. When you step gas pedal down and rev up engine , pull tilt back at same time to see if rpm increases. If not. Check fuel filters
  • Posted 19 Apr 2024 05:55
  • Reply by ron_k
  • North Dakota, United States
4kliftman
edition #1228 - 1 May 2025
Terberg YT182
Hangcha CBD15
China
USD1,600
