Please Help to fix Komatsu FB18EX-7 problem
I am facing a problem with Komatsu forklift FB18EX-7
the problem is that when i switch key ON, error code no 16 Displayed,
please described about the problem and ramdies,
  • Posted 10 Mar 2011 15:47
  • By tanveer_h
  • joined 9 Mar'11 - 8 messages
  • Jeddah, Saudi Arabia
+966550457264
Dear bruce,
I didnot rcvd error code list,
Please send it again on
tanveer underscore study at yahoo dot co dot uk
  • Posted 15 Mar 2011 14:12
  • By tanveer_h
+966550457264
dear bruce,
I checked my email and not found the requested info, please resend again, ([email address removed])
  • Posted 13 Mar 2011 06:08
  • By tanveer_h
hello tanveer_h
please check your mail i have sent the info you requested.
if not you can mail me at
bcline at umsinc dot net
  • Posted 13 Mar 2011 01:36
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
Thanks alot for ur responce,
As you suggested, i checked the battery charger, its getting stop at full charge. that time battery on 52 voltage.
i put other battry which is working already to other lifter.
but still error no 16 coming.
i would like to share with u, after long time the error no 2 apears for one second only.
waiting for ur responce...
Do u have the error code list with fault description?
if u have please send me on my email address tanveer underscore study at yahoo dot co dot uk.
  • Posted 12 Mar 2011 20:52
  • By tanveer_h
code 16
battery voltage is too high.
make sure function 15 is set to the proper battery voltage being used.
also make sure the charger for the battery is adjusted properly so it is not overcharging the battery.
this unit should be compatable with the EV100 LX handset
if this code happened right after the battery came off the charger then i would look at the charger settings.
usually this code accures when a battery of the wrong voltage is installed in the truck. it is just the opposite of status code 15 which is (battery voltage to low)
  • Posted 12 Mar 2011 02:56
  • By bruce_c
Noblelift
