Place handle in neutral position message
I am looking for the button sequence on the traction controller to calibrate the multifunction handle. Traction controller has 4 buttons with a digital display. Currently does not show the forward or reverse movement with the handheld input. mib does see that the operator presence and brake pedal switches are functional. Also the truck will code out with the red triangle. Shows message to check error code, but the handheld shows no error code present.
  • Posted 8 Mar 2023 07:09
  • By CDAVID
  • joined 8 Mar'23 - 2 messages
  • Illinois, United States
David
yep garland there is a calibration routine that has to be done on the travel pots and the hydraulic pots in the handle. Pages 22 and 23 in the MIB calibration section of the electrical section tells how to do the calibrations.
  • Posted 17 Mar 2023 11:35
David
Since you have a MIB I believe you are correct. I will see what info I can find and get back with you. Thanks
  • Posted 17 Mar 2023 10:29
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
So the only message that is displayed is is "check fault codes", "no hydraulic functions ". I believe that the calibration sequence is done on the 4 buttons A,B,C, and D buttons on the MIB. Any help would be appreciated.
  • Posted 17 Mar 2023 03:51
  • By CDAVID
David
if the handle knuckles are worn or the positon sensors in the handle do not hold a good centering position you can calibrate it till the cows come home but you will constantly get the handle not centered message.
Sure, try a calibration but if that does not hold up then you need a new or reman handle.
  • Posted 11 Mar 2023 11:50
David,
Do not have the steps in front of me, retired. If I remember correctly, hold the horn button in the on position. Turn key on, release horn then quickly turn it on and release again. Display should show handle calibration. Move handle completely forward and reverse within 10 seconds. Make sure when moving handle it is smooth and stop at each end for 2 seconds. If the display does not show handle calibration, press the brake pedal one time and check screen again. Be careful as you can access the wrong menu and change lift parameters. This could stop the operation of the lift. Good Luck
  • Posted 10 Mar 2023 04:42
  • By garland_m
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
May 14, 2026 - Blair Athol, South Australia, Australia
Jason Morgan Jason Morgan
director of aftermarket, Noblelift North America
sales manager of Texas, Taylor Machine Works
board advisor, Humanitarian Logistics Association
lead sales - Northern Europe, Camso Construction
