Pimespo Four/D Model 6355
Hi
Can anyone help with my four way Pimespo reach truck.
Problem occurs when first starting up and what happens is the truck won't change from 4 way to normal until 10 minutes after its turned on. Once it sterts to work it works normal until switched off again.
Have checked switches and looked for bad connections and haven't found anything.
Truck has 2 Sevcon controllers under the arm rest if that helps.
Any ideas.
Thanks
  • Posted 29 Dec 2012 02:21
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
i have one i think maked pimesco also has linde data plate any info you have would be great help as hasnt broken down yet
  • Posted 4 Jan 2013 08:08
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
hello kev
I will write you on your mail
King regards
  • Posted 4 Jan 2013 05:37
  • By nemanja_k
  • serbia, Serbia
nemanja k
Thanks have checked Potentiometer in left wheel, also all the leds seam to be lighting up but I don't know if they are in the right order. Do you have any more ideas or information.
Thanks
Kevin
PS is this a another truck badged up as a Pimespo
  • Posted 4 Jan 2013 03:23
  • By kevtwad
Please look in front right or left wheel you must to have potentiometer is he ok and wiring,than look valve block on him you have led diode for every function.You error is very heavy.Tell me what you do.
  • Posted 29 Dec 2012 22:04
  • By nemanja_k
  • serbia, Serbia
Muncie, IN, United States
Deborah Baker Deborah Baker
Toyota 02-2TD20
Toyota 02-8FD25
