Picker turn on then off after test
Hey guys this picker driving me nuts the picker turn on then off after the test the display turn off and only showing the green dot and orange traction and lift won't work now this get tricky if turn on and over on key switch after 15 min it will work just for a few minutes then it shut off on it own on Access card 3 give a code 336 then the scm card give 281 code Any help thanks
  • Posted 2 May 2024 02:09
  • By Steven_Orellana
  • joined 15 Jun'21 - 5 messages
  • New Jersey, United States
Steve
I already found the problem the scm wasn't it there was a wire that broke off on the connecter
thay go on Distribution board. Also found the Positive cable that go from battery connecter tips was heavy Corrodent. Clean the tips and it work I never seen that before but thank you for the info
  • Posted 10 May 2024 03:40
Steve
Looks to be a steering module controller timeout. I recommend replacing the scm if the event codes reappears again.
  • Posted 10 May 2024 03:01
  • By DyslexicNerd_01
  • Wisconsin, United States
