park brake isn't disengaging
I have a J40ZT serial J160N02959D that has started having issues with the auto park either not releasing or completely releasing (the park indicator seems to be working) Moving it 10 or 15 feet causes a hot brake smell.. I do not have the pass code as it was bought recently at auction. Is there anything I can check for (fuses, links, adjustments) before calling a tech out?
  • Posted 4 Mar 2020 22:22
  • By Paul_Jackson
  • joined 4 Mar'20 - 1 message
  • Tennessee, United States
also try 55555
  • Posted 5 Jun 2020 01:32
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
Most hyster pass codes are based off vin # last 5 numbers
but on keypad you have 12345
so take 12345
67890
then vin last 5 didgits 02959
Then 0 becomes 5 2 is 2 9 becomes 4 5 is 5 9 becomes 4
so passcode should be 52454 unless someone has changed it.
hope that helps you get into dash.
  • Posted 2 Jun 2020 12:10
  • By Jared_Smith
  • joined 27 May'20 - 3 messages
  • British Columbia, Canada
Terberg YT220
Crown WP302020
