Toyota 8HBW23:
Pallet Jack doesn't go down.
I have no error codes. It's al the way up and now doesn't want to go down at all. All I hear is a click sound. It is coming from the solenoid lowering valve.
I assume if I hear it click when I push the button that something is working. If I unplug a wire, there is no more clicking. I can only assume the solenoid is good, But it's clicking, so is the valve working? Is it stuck. Is this really a thing that goes bad?
Can it be something else that is causing it not to go down that I'm missing?
  • Posted 15 Apr 2025 03:21
  • Discussion started by JBDragon
There is a height proximity limit switch on the right side of the machine undo the covers...verify that is still mounted properly and operational
  • Posted 15 Apr 2025 06:35
  • Reply by Matthew_Reed
Fixed it, kind of. It seemed to be stuck up for some reason. Once I got onto the force and hit the button it went down. It was kind of sticking at first, but after going up and down a few times, it started going back down on its own just fine.
With the weight of 4 lead acid batteries and yet it wouldn't drop on its own seems strange. So the valve was clicking open and working just fine, it was just stuck up.
  • Posted 15 Apr 2025 04:46
  • Modified 15 Apr 2025 04:46 by poster
  • Reply by JBDragon
Louisville, KY, United States
Dubuque, IA, United States
Noblelift
edition #1228 - 1 May 2025
