orbit steering gear pump for Nissan MCPL02A25LV
The pump was pulled out only show CHAR-LYNN EATON' without model #. If anyone can help me find out the more info? Thanks a lot.
  • Posted 31 Mar 2014 07:15
  • By li_w
  • joined 16 Nov'09 - 49 messages
the cylinder is quite a lot cheaper than the ps valve ey?
  • Posted 18 Apr 2014 12:48
  • By RCAV8TOR
  • Alabama, United States
the rod was bent and damage the inner wall of cylinder. the whole cylinder unit is $358.
  • Posted 16 Apr 2014 08:15
  • By li_w
I usually replace the cylinder assembly rather than reseal due to cost, we sell the cylinder assembly for under 500.00 which is not much more than a seal kit and labor to install. If you are replacing the orbital valve, I agree with the above statement that you should replace the valve as an assembly rather than reseal to prevent headaches.
  • Posted 6 Apr 2014 13:17
  • Modified 6 Apr 2014 13:24 by poster
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
ok, will remove the cylinder and check it.
  • Posted 6 Apr 2014 11:38
  • By li_w
lw
The cylinder is simple as it has a center oring and seal. Remove the cylinder and inspect the rod for bend. If rod will slide back and forth off unit then i am doubting it is the cylinder but in the ps valve it's self or the ps valve. I would check this as it can save you money and time. ||It's best to diagnose the problem correctly than just throwing parts at it.
  • Posted 6 Apr 2014 11:11
  • By RCAV8TOR
i think it's better for complete ps cylinder. the wheels do not turn counter clock wise but may turn clock wise.
  • Posted 6 Apr 2014 09:54
  • By li_w
part number for complete ps cylinder assy or seal kit? describe the issue
  • Posted 6 Apr 2014 09:33
  • By RCAV8TOR
Power steering cylinder is bad. Please give me the Nissan part number. Thanks!
  • Posted 6 Apr 2014 09:26
  • By li_w
li w being it is a L02 model and has some age it and depending on hrs just go ahead and replace the complete valve as it will be less headache. The valve housing will probably have lot of wear depending on hrs. if it has low hrs then a seal kit will suffice but if unit has 6000+ i would just replace it as a complete unit.
  • Posted 3 Apr 2014 12:56
  • By RCAV8TOR
thanks a lot.
  • Posted 1 Apr 2014 11:07
  • By li_w
The Nissan part number for the seal kit is 49440-FJ100 and the whole unit is 49410-FC300
  • Posted 31 Mar 2014 21:10
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Board member, UKMHA
