old Baker forklift
I recently aquired this Baker lift, its a model B-150-PD, #15000, Deutz air cooled 6 cylinder diesel. Does any body know anything about this lift? I cant fine squat on the internet
thanks
  • Posted 19 May 2010 04:16
  • Discussion started by ifurlong
Showing items 1 - 15 of 17 results.
I think there set up has a cap on the top of both ends of the steer cylinder. If you remove the cap there should be a snap ring under it , Remove the snap rings and pry up on each end to remove the cylinder.
  • Posted 5 Jul 2019 22:10
  • Reply by duodeluxe
  • United States
duodeluxe
Duo deluxe might be a long shot but I have one just like his and I need to know how to get the steering hydraulic cylinder off to get it serviced out and I cant find anything about it
  • Posted 3 Jul 2019 23:27
  • Reply by morgan_r
Duo deluxe how could I contact you and ask you a couple of questions.
  • Posted 15 Apr 2017 01:38
  • Reply by misael_l
Misael Linan
If it runs why do you need to tow it up the trailer? That truck should be able to climb anything when running correctly.
  • Posted 15 May 2012 21:42
  • United States
duodeluxe
Do you have any more photos of this forklift? I may have the same model but am not sure
  • Posted 15 May 2012 01:27
  • Reply by Verde
  • Illinois, United States
the serial number is 320509000-970
does anyone here know where the short circuit valvs are so I can tow it up onto a trailer?
I cant fine them anywhere
and it was moved a couple times without these valves being opend, I hopeit isnot damaged?
  • Posted 29 Dec 2010 01:45
  • Reply by ifurlong
I would need to know the serial #. Without it the parts manual would be correct but there were some changes in the parts that would not be.
You can contact me directly at gitrucks at adelphia dot net.
  • Posted 2 Jun 2010 22:06
  • United States
duodeluxe
It must be FJF50 It has air tires and a 6 cylinder continental let me know about service and parts manuals thanks
  • Posted 2 Jun 2010 07:18
  • Reply by donald_m
Donald; You have the wrong model #. It is either FJD50 or FJF50. The FJD50 has cushion tires and 4 cylinder Continental engine. The FJF50 has pneumatic tires and a 6 cylinder Continental engine. I have service and parts manuals for both.
If the plate is missing the serial # should be stamped on the right hand side of the frame right next to the floor board.
  • Posted 1 Jun 2010 21:34
  • United States
duodeluxe
Thanks for the info any more you can give me would help a lot on this machine wish I could find a manual.
  • Posted 31 May 2010 21:02
  • Reply by donald_m
At that age of machine it will be more temperature dependant than anything else. I see you are in SC. I would start with a good name AW46.
  • Posted 31 May 2010 08:57
  • Reply by JonG
  • United States
I have a 1969 Otis Baker FJP 050 forklift it runs fine but I need to know what type and kind of hydraulic fluid it needs if any one can tell me
  • Posted 31 May 2010 07:50
  • Reply by donald_m
Obviously, it is impossible to know what it is worth just knowing the model #. It COULD be worth any where from $6,000 to $12,000. What kind of manual do you want? You can e mail me at gitrucks at adelphia dot net
  • Posted 20 May 2010 01:50
  • United States
duodeluxe
one thing I would like to know is about what its worth.
and it would be nice to get a user manual for it
  • Posted 20 May 2010 01:29
  • Reply by ifurlong
It IS a Linde. The serial # should start with 320........
It is a 15,000# capacity truck equipped with a 6 cylinder Deutz air cooled diesel engine and is hydrostatic drive.
  • Posted 19 May 2010 21:37
  • United States
duodeluxe
UN Forklift FBR25NQC3
Maxlion MTF30-45-2WD
edition #1235 - 19 June 2025
Lift Technologies Inc.
