Linde (& Baker) H16D-03:
OIL FROM DRIVE WHEEL
WHAT IS THE BEST WAY OFF TAKING OFF THE DRIVE WHEEL UNIT.ITS LEAKING OIL OUT OF SEAL.
I SEE THE RING OF BOLTS AROUND IT. IS THAT IT TO TAKE OFF DRIVE UNIT?
  • Posted 19 Dec 2014 06:39
  • Discussion started by greasespoon
  • somerset, United Kingdom
Also, when you order the seal kit, it comes with two kits, save one for the next drive axle seal
  • Posted 11 May 2015 12:49
  • Reply by edward_m
  • Posted 11 May 2015 12:48
  • Reply by edward_m
Disconnect the hydralic lines going to the drive. Their on the inside, their is a banjo fitting and also take out the pipe spacer.When you pull it out, then you need the linde tools to disasemble it.You will need a multiplyer to loosen the spring tension
  • Posted 11 May 2015 12:46
  • Reply by edward_m
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
edition #1234 - 12 June 2025
SMV (Konecranes) 4535TB5
Hangcha CBD15
China
USD1,600
Your Focus
