Toyota 8HBW23:
numeric keypad
numeric key pad not working.
  • Posted 1 May 2019 04:04
  • Discussion started by hyster123
Showing items 1 - 15 of 16 results.
Hi, does anyone know where I can find a user's manual and troubleshooting guide?
  • Posted 3 Nov 2023 00:44
  • Reply by Reece
Reece
Usually its 1 followed by green button.
  • Posted 17 Apr 2021 02:00
  • Reply by Yidnecks
You get what you pay for.... and you haven't paid.
Hi there
I already get a Toyota 8HBW23 walkie pallet truck, but without any information including pin code for activation.
Are these codes standard for every Toyota walkie pallet or individual for each equipment. I revised the whole device and found anything related to pin code.
Any clue on this?
  • Posted 17 Apr 2021 01:01
  • Reply by yandier_m
  • Havana, Cuba
YMG
Hi Yidneck,
if it is not a bother request...
Do you want to share me how to bypass the numeric keypad in a Toyota 8HBW23 electric pallet jack?
I will really appreciate it
Luis
  • Posted 8 Oct 2020 08:38
  • Reply by luis_v
  • Mexico
lvelasco@insercomm.com
You may have to contact the dealer to do this request as the cable and software are proprietary. It is a option to have the keypad exist on the unit. Not a requirement to operate the machine.
  • Posted 16 Mar 2020 03:05
  • Reply by ron_k
  • North Dakota, United States
4kliftman
Hi Ron_K
there seems that accessories needed to bypass the keypad are not reachable that easy
thank you!
  • Posted 11 Feb 2020 09:22
  • Reply by luis_v
  • Mexico
U will need the laptop/program and data cable to turn of the feature in the parameters. You can also shut off the need for the controller key so no need for cable and key to change this again. If you have access to these , this is the only way to do this change.
  • Posted 11 Feb 2020 04:06
  • Reply by ron_k
4kliftman
Hi Everyone
Can you let me know how to bypass the keypad?
thank you / Luis
  • Posted 11 Feb 2020 02:40
  • Reply by luis_v
  • Mexico
If it shows boot and doesn't power up. May have to reinstall software. If any boards are replaced you have to reinstall software Any signs of moisture, replace the card and software
  • Posted 10 Jan 2020 02:19
  • Reply by ron_k
4kliftman
Are you able to bypass the keypad without having the keypad already working? I have the programming key, but the service manual states that I need to enter the keypad code to get to the parameter menu. I can't enter the code because the keypad circuit on the board is bad.
  • Posted 5 Dec 2019 06:30
  • Reply by Bean06
  • Missouri, United States
Bad keypad.
Every time you try to move the keypad it breaks. So putting in a new one doesn't help unless your very gentle and now how to bend the wire ribbon without damaging it. Best way is to bypass keypad.
  • Posted 31 May 2019 05:44
  • Modified 31 May 2019 05:46 by poster
  • Reply by Yidneck
Do you repair electric forklift trucks?
I have a problem with this truck.
I can't turn on the truck with the keyboard., change the controller, the rudder wiring, the keypad, in the dispay indicates boot, but does not illuminate the keypad when entering the code.
  • Posted 31 May 2019 02:19
  • Reply by alonso_reyes
  • kyku, France
And to bypass the keypad you need the programming key and it's down through the throttle and horn switch.
  • Posted 7 May 2019 04:36
  • Reply by Yidneck
The 7hbw23 has decent key pads. It's the newer model 8HBW23 that's messed up.
  • Posted 7 May 2019 04:34
  • Reply by Yidneck
The keypads are simple plug & play, just replace it - the pin codes are stored in the tiller head card.
Its very rare for these keypads to fail, some of the buttons do wear out eventually but I've not replaced that many in the last 15 years.
  • Posted 7 May 2019 00:17
  • Reply by Forkingabout
  • england, United Kingdom
Crown CG33P5
Terberg YT182
Terberg BC182
Ncn 85TH
Ncn 85TH 2017
Linda Häkkilä Linda Häkkilä
Bolzoni SpA (Group HQ)
