NOT WORKING ERROR 1
Hi , I am having a problem in bt
Toyota Model no. POW1200HSE ,
Error code 1 on the logic box
display , If it is posibl to get.
trouble shooting manual. Thanking
you...
  • Posted 1 Mar 2014 03:02
  • By shashank_v
  • joined 27 Feb'14 - 22 messages
  • Haryana, India
shashank_2436@yahoo.in
SV
Showing items 1 - 20 of 22 results.
Good, Can you send me your Mob No.. Please.. on my mail id..
  • Posted 3 May 2014 19:37
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Thanks for the information sir , there is a fault of control v blockage
and now my OPW is running well thanks....
  • Posted 3 May 2014 04:20
  • By shashank_v
  • Haryana, India
SV
This is The Part same as Reach Truck, What you have.. Model BT RRB Series reach truck part.
  • Posted 2 May 2014 22:43
  • By gopal_s
  • karnataka, India
GOP
Dear sir , is there any way to by pass that magnetic switch
  • Posted 2 May 2014 04:31
  • By shashank_v
  • Haryana, India
SV
Change the Magnet switch- 214259-050, of below the mast..Ur problem will get solve..
  • Posted 26 Apr 2014 22:36
  • By gopal_s
  • karnataka, India
GOP
I am having problem is that my op lift is very slow when coming down it is just above 0.
  • Posted 23 Apr 2014 03:39
  • By shashank_v
  • Haryana, India
SV
Thanks for information.......
  • Posted 25 Mar 2014 20:35
  • By shashank_v
  • Haryana, India
SV
They are both part number 200319.
The -002 & -006 are just the software release versions, -006 is just a newer software release of -002.
  • Posted 6 Mar 2014 05:28
  • By Forkingabout
  • england, United Kingdom
BT PART 200319-002 Part no. of OPW1200HSE , BT PART 200319-006 Part no. of OPW1000HSE
  • Posted 6 Mar 2014 04:41
  • By shashank_v
  • Haryana, India
SV
If the part number on the sticker is the same then YES.
  • Posted 6 Mar 2014 04:38
  • By Forkingabout
Sir,
If I want to interchange logic box A2 card from OPW1000HSE With OPW1200HSE Can it posibl to do.
  • Posted 6 Mar 2014 04:30
  • By shashank_v
  • Haryana, India
SV
I am also intrested to know about the emergency mode. how can we do this ?
  • Posted 5 Mar 2014 05:12
  • By shashank_v
  • Haryana, India
SV
Steering working is a good sign as that means you have a traction fault.
Brake is only on the back wheel, either manually release the brake then you can push / steer the truck out the way.
OR pick the back end of the truck up so the drive wheel is just clear of the floor & tow it out the way.
  • Posted 5 Mar 2014 04:46
  • Modified 5 Mar 2014 05:02 by poster
  • By Forkingabout
only steering is working...
I did'nt know about emergency mode , Is there any way to move the truck
  • Posted 5 Mar 2014 03:59
  • By shashank_v
  • Haryana, India
SV
So the truck wont drive at all after starting it up?
What functions are working on the truck?
Is the steering working?
Does the brake release when you go for traction?
Can you get the truck to go in to emergency mode with the joystick dance?
  • Posted 5 Mar 2014 03:02
  • By Forkingabout
sir ,
201 & 202 led lights up but I am having same problem Erorr 1 only steering is working
  • Posted 5 Mar 2014 02:25
  • Modified 6 Mar 2014 04:35 by poster
  • By shashank_v
  • Haryana, India
SV
Thanks for the information...
  • Posted 1 Mar 2014 05:09
  • By shashank_v
  • Haryana, India
SV
Be a good idea to jack up & block the truck BEFORE you bypass the dead man handles if your working on your own!
OR get a 2nd person to operate the truck / stay in the cab.
A wet rag placed on each dead man handle will latch it on.
You can check the status on the A2 card.
Pin 201 is the left dead man
Pin 202 is the right dead man
Green led lit up means the dead man / switch input is activate.
  • Posted 1 Mar 2014 05:04
  • By Forkingabout
The truck is basic free ranging.
  • Posted 1 Mar 2014 04:50
  • By shashank_v
  • Haryana, India
SV
You haven't mentioned if the truck is:
Just basic free ranging?
Fitted with wire guidance?
Set up for rail guidance?
As for the slow speed:
Brake air gap adjusted correctly?
Both the optical speed sensors on top of the traction motor correctly adjusted?
  • Posted 1 Mar 2014 04:38
  • By Forkingabout
ROYPOW
