not starting
Hi, I have a hyster S60XM serial number is D187V17353X. Has a 2002 mazda 2.2l engine in it. Im getting fire to my coil and plugs. Lift will crank over and start hitting as long as key is turned soon as I let off of the key it dies out. Almost like a fuel issue, I have cleaned the carburetor it still does it. Is there anything these lifts are notorious for that could be causing this or is it going to take getting a service tech out to hook it up.
  • Posted 5 Mar 2015 01:37
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
or a faulty keyswitch
  • Posted 5 Mar 2015 13:42
you may also have something as simple as a wire off on the key switch.
  • Posted 5 Mar 2015 10:55
  • Modified 5 Mar 2015 12:06 by poster
Electronic or point ignition , if points then check the ballast resistor on + side of coil(. 12 volt when cranking and approx 7 volts when running)
Timing belt could have jumped a tooth/. Food for thought
  • Posted 5 Mar 2015 07:14
  • By BrewCrew
We`re here for a good time
This unit is a gas engine.
  • Posted 5 Mar 2015 01:44
  • By cgarner1979
Briefs United States
Linde Material Handling
Aichi RX07B
JLG G12-55A
