not moving front and back CAT30
ENGINE IS STARTING.THEN IT IS INDICATES ! SYMBOL.NOT MOVING FRONT AND BACK MOVEMENT AND NOR HYDRAULIC MOVMENT TOO.FORK UP AND DOWN MOVMENT.PLS GUIDE ME.....TO MAINTENACE.
  • Posted 25 Jan 2010 16:44
  • By sickandar_s
  • joined 17 Aug'09 - 9 messages
  • Dubai, United Arab Emirates
sickandar
thank you chublil.i take one more try on this idea....
  • Posted 28 Jan 2010 04:16
  • By sickandar_s
sickandar
sickandar, I believe you may have a bad mast lock relay or main relay. Also if Im not mistaken, the seatswitch, directional switch, and hydraulic lock coils all are tied into the same circuit from the main ECU.
  • Posted 28 Jan 2010 00:48
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
Not yet.ok thanks.
i am trying all those things and contact you with result....
  • Posted 27 Jan 2010 00:03
  • By sickandar_s
sickandar
this is a gas or lp unit? does the engine rev up? have you tried moving the relays in the relay box and checking the fuses?
  • Posted 26 Jan 2010 23:56
vehicle serial no. T14E - 35221
I CHECKED ALL THOSE THINGS.
NO CHANGES IN EXISITING PROBLEMS........
ANY OTHER CHECK UP PLS..............
  • Posted 26 Jan 2010 16:35
  • By sickandar_s
sickandar
have you tried to short across the wires to see if that makes any changes?
what is the serial number?
  • Posted 25 Jan 2010 23:40
Thanks Mr.Edward, just few minutes ago,i have checked those wiring and i checked continuty too.But problems are as it is.Pls guide me little bit eloparatly......
It is showing same indication (!)
  • Posted 25 Jan 2010 22:29
  • By sickandar_s
sickandar
seat switch or wiring to seat switch.
  • Posted 25 Jan 2010 21:27
Maxlion FB35LI
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion FB35LI
USD1
