not driving
Fwd/Rev contactors come in and go out right away, no codes on dash. Lift ok, battery good, 50.2 v. Also dash has side buttons, how do I access codes.
  • Posted 16 Jul 2024 16:24
  • By Cam_Oberer
  • joined 3 Apr'24 - 14 messages
  • Alberta, Canada
Cam oberer
Check drive motor brushes. Turn steer wheel 90° and see if one or the other motor operates. Check contactors over for all 3 sides of tip condition. Check shorts to frame. Nothing higher than 18 volts. Brake switch on hand brake leaking.
  • Posted 19 Jul 2024 06:13
  • By ron_k
  • joined 2 Apr'15 - 145 messages
  • North Dakota, United States
4kliftman
You say 50.2 volts that sounds like surface charge have you put meter into battery cables and checked under load ? Sometimes the battery will show a charge until you turn on key and try to use the lift and then you can see it drop drastically
  • Posted 17 Jul 2024 04:09
  • By John_Bradley
  • joined 10 Aug'22 - 304 messages
Jb69
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
Taylor TT300
USD98,500
Taylor T650L
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
