None runner but power at starter
Hoping someone on here can atleast point me in the right direction.
Have a Linde truck that won't start. Got power at ignition,power to computer and power to starter motor but when you turn ignition relay clicks but no starter.
Brake pedal switch appears to be ok and can confirm relay does click as you press brake pedal down but still no sign of starting.
This has been an intermittent fault for some time and last time we fixed it we removed starter checked it and refitted and then it worked again...
But we never found the Fault. Any ideas would be greatly appreciated as there appears to be a lot of **** on these trucks that potentially could Stop the truck firing into life. Truck has never been a bad runner and always ran faultlessly it's just this starter fault that has occurred twice now...
Thanks in advance,
  • Posted 8 Aug 2016 21:09
  • By Multiblokk
  • joined 26 Aug'15 - 11 messages
  • Rogaland, Norway
Do a load test on battery. Had a battery that cranked great but would only start 2nd time i tried, every time. Jumped off my van and it started every time. load tested battery and voltage dropped to 6 volts. load test fuse. Check voltage at solenoid when trying to crank motor.
  • Posted 8 Oct 2016 13:49
  • By edward_m
  • joined 11 May'15 - 111 messages
most likely a relay
i'm not sure where it is located on this machine though
usually they have relays under dash or behind seat on main fuse/relay panel, but for this model i'm not 100% sure
  • Posted 8 Aug 2016 22:15
Starter has been out on bench and works 100% fine. 12v at starter on one side but when you switch gear to start position and turn key nothing happens.
One single wire runs to the back of the solinoid on the starter.
I suspect this is not receiving a message to make starter work but unsure where this gets its signal from? Maybe you know?
  • Posted 8 Aug 2016 21:53
  • By Multiblokk
  • Rogaland, Norway
i would check your voltage at the starter and solenoid starter wire from the keyswitch, make sure you are getting battery voltage in start mode.
one of the biggest issues i've found with starting problems is a weak battery, bad connections or faulty solenoids.
If you have good voltage at the starter wire at the starter then i would pull the starter and have it checked and/or rebuilt.
  • Posted 8 Aug 2016 21:47
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Morooka MFD20
Hangcha CBD15
China
USD1,600
