Unicarriers (& Nissan) LO2:
non start of gas forklift
can any one please help with the following error codes: E24, E31, E35, E36 its causing a non start problem, NISSAN L01/L02 LPG Engine, i have disconected the cam sensor and battery to reset the ECU but no luck.
  • Posted 17 Aug 2011 05:42
  • Discussion started by arnie
  • western cape, South Africa
arnold@rafforklift.co.za
e23= throttle position sensor circuit error
e34= ignition circuit signal malfunction
  • Posted 19 Aug 2011 20:21
  • Reply by edward_t
Hi there Edward, i managed to get the machine started and running by disconnecting all controllers and checking wiring etc. used a water repellant on all the plug connections and that sorted things out, the error codes dissappeared and have a new set of error codes as follows: E23, E34, any idea what that could be ? tried the foot pedal clear code but no luck.
kind regards, Arnie.
the truck details as follows: model: MCPL02A25LV
Chassis no. CPL02-9P6966 0107
Type: LP
  • Posted 19 Aug 2011 00:45
  • Reply by arnie
Not all trucks are fitted with an LPS switch, just trucks that were purchased with the "LPS" kit of added safety options. If your truck has one, when new, the truck had stickers on the sides that identified it as an LPS truck, and the switch would be somewhere in the heavy cable negative circuit between the battery and the frame, and would have a method of opening the circuit that did not require the hood to be opened to engage the switch to open the circuit.
If your battery is charging 14.2 at the battery post (not neg on the frame of the truck), with all the lights and accessory on, then it is NOT likely that the charge circuit is the problem. if it changes voltage between the frame and the battery post, then the ground may be where the problem is.
the codes E24, E31, E35, E36; break down as;
* E24, is the accelerator pedal circuit sensor malfunction
E31, is the ETC (electronic throttle control motor) circuit.
E35, is the LPG injector circuit malfunction.
E36 is the LPG fuel pressure sensor malfunction.
What is the possibility that you have gotten moisture and dirt into the connectors of the ECM?
Do you have access to a 'test' ecm to test the ecm by swapping it temporary?
I have seen some ECM where the pins to the connectors got pushed back into the ECM due to debris or mis-fitting the connector.
* because the code e24 is related to the accel pedal circuit, you are going to have to have someone with the program and laptop to come out to clear the codes as a code for the Accel pedal can not be cleared using the accel pedal "dance".
  • Posted 17 Aug 2011 20:20
  • Modified 17 Aug 2011 20:59 by poster
  • Reply by edward_t
Thanks for replying Edward, makes lots of sense what you just said, however the charging rate was 14.2 volts, have checked the wiring on the alternator -ok, the kill switch is what i need to check, the battery has been charged and i'm doing a loadtest on it as we speak, where about is the LPS kill switch situated? before the non start problem the engine would rev up normally for only 5 minutes and then would just idle. your advice will be treasured.
  • Posted 17 Aug 2011 15:37
  • Reply by arnie
a lot of the time when it is a bunch of codes, it can be related to the battery state of charge and the charge system. does this unit have an LPS rated system? some times if the LPS version kill switch does not make excellent contact internal to the switch, or if the heavy cable on the alt is broken or loose you can have a system that charges, but not enough.
  • Posted 17 Aug 2011 10:49
  • Reply by edward_t
edition #1235 - 19 June 2025
