Linde (& Baker) 394:
No voltage at the gas solenoid valve.
I have a problem with a Linde 394 T (VR6 engine without electronic throttle) The truck stopped starting, no voltage on the gas solenoid valve. When I unplug the plug and power the solenoid valve from the battery, the truck starts and works fine. I suspect a problem with the controller, but I'm not sure. The cables to the solenoid valve have been checked, Any ideas? Thank you.
  • Posted 17 Dec 2024 06:07
  • Discussion started by tomason2
  • -, Poland
serwiswojnarowski@gmail.com
On Linde the positive is constant the negative is broken either by switch or controller
If no neg from controller and no codes I would suspect a bad connection or a broken wire
Push down on all relays in the relay fuse box
I had one that apparently they had hit a large hole and caused relay to jump up and lose connection also check wiring and plug on rpm sensor
  • Posted 20 Dec 2024 04:27
  • Reply by John_Bradley
Jb69
No error codes. According to the diagram, the plus wire goes through the fuse and it is OK. The minus wire goes straight from the engine control unit.
  • Posted 20 Dec 2024 04:03
  • Reply by tomason2
  • -, Poland
First are you getting any codes ?
The lock off is operated by the engine controller when the controller sees that engine is turning over via the rpm sensor and all safety inputs are there it sends a voltage
Through the relay - fuse box to the lock off
If no codes on dash and you are getting voltage at lock off I would start at lock off
A lot of people forget about the negative side of the equation so also check the brown wires
To insure you have a good negative
  • Posted 20 Dec 2024 03:44
Jb69
Toyota 5FD60
JLG G12-55A
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Hangcha 78XEN
Your Focus
