No travel
I'm working on a 7 series Toyota fl with no travel and no error codes.
When I raise the front drive wheels off the ground and with direction selector fwd or rev the right wheel spins correctly while the left wheel shudders turning about 10 rpm vs the right wheel at approx 2600 rpm.
The diagnostics screen shows 36 volts to both but the left side has twice the temperature at both the motor and driver. Any easy way to tell if it's the controller or motor or is there something I'm missing? And why no error codes?
Thanks
Bill
  • Posted 3 Jul 2014 04:48
  • By bill_d
  • joined 3 Jul'14 - 2 messages
  • Washington, United States
Most likely the Speed sensor bearing in the motor, we have replaced several of them in the 7FBE models
  • Posted 3 Sep 2014 02:16
  • By eoin_o
  • joined 14 Dec'13 - 14 messages
  • Co Tipperary, Ireland
No, wheels turn freely in neutral.
  • Posted 3 Jul 2014 06:00
  • By bill_d
Are the brakes locked up on the left side?????
  • Posted 3 Jul 2014 05:47
  • By kevin_t
SMV (Konecranes) SL37-1200A
Hangcha FLDCXT160
