no throttle
have a lift that has no throttle, and all controls work without the seat switch pressed, as well as it goes into forward and reverse without the seat switch presses.
has anyone seen this before?
  • Posted 27 Aug 2013 04:41
  • By bowlerwa
  • joined 24 Aug'12 - 35 messages
  • Washington, United States
Are there any codes showing on the multi display monitor?
  • Posted 29 Aug 2013 04:53
  • By L1ftmech
  • Tennessee, United States
thanks for your input, all looks good.
I am leaning toward the harness.
Looks like lots of work ahead
  • Posted 29 Aug 2013 01:23
  • By bowlerwa
Yes, I have seen this.
Inspect the ECM/controller cover for damage from battery leakage.
The Toyota battery tray can allow battery acid to leak off its left front corner and drip directly onto the ECM/controller cover below the tray.
Acid WILL eat a hole in the cover if the condition is not caught and corrected in a timely manner.
Once acid has created a hole in the ECM cover, acid will then enter the ECM enclosure and as fate/design would have it, the acid can then track right down the seat switch harness to the multi wire latching connector where it will spread out along the wires and corrode and/or contaminate the whole works.
Most of the incidents I have encountered with this had symptoms where the trans drive would disengage as if the seat had been vacated, but the seat was still occupied.
Have not run across any cases of the transmission just spontaneously jumping into gear of its own accord.
Are you seeing any trouble code on the multi display monitor?
If so, what codes.
  • Posted 27 Aug 2013 11:46
  • Modified 29 Aug 2013 22:42 by poster
  • By L1ftmech
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
VETTER Forks, Inc.
