No Throttle Response
Toyota 8FGCU25 Ser 27527
So start this unit up at customers no throttle all other functions work lift tilt forward reverse No Codes on dash sometimes the throttle will respond other times it will not. It also started to run rough though about Throttle position sensor but no codes Having truck brought into shop today will post more after I look at it some more just looking to see if anyone has encountered this before
  • Posted 22 Jul 2015 01:29
  • By grant89
  • joined 2 Jul'09 - 28 messages
  • Minnesota, United States
Similar issue, intermittent no-response from throttle. Key on and check throttle function, I could hear the throttle motor cycling with the accelerator pot. I also was missing a vacuum cap, and had throttle response briefly once I replaced the cap. However, now the engine would rev up, but not hold RPM; gradually the engine dropped revs and died. Swapped the MAP sensor (actually just a vacuum sensor in this application) and everything cleared up.
  • Posted 1 Jul 2025 08:56
  • By CSCFR
  • joined 26 Feb'10 - 22 messages
Jerry
Thanks for posting the fix on this, just had the exact same thing happen, and sure enough it was missing a plug on a vacuum line!
  • Posted 23 Mar 2023 03:53
  • By BentWrench
  • joined 27 Aug'19 - 5 messages
  • Washington, United States
Nevermind found the problem a vacuum plug fell off the carb cant find a vacuum line that went to it so we plugged it runs like a dream
  • Posted 22 Jul 2015 04:56
  • By grant89
edition #1291 - 23 July 2026
In the latest Forkliftaction News , it is a week of product launches and humanoids. Chinese equipment manufacturer Heli launches its new heavy-duty G3 Series 12T-18T capacity forklifts on to the global market while Clark launches two new lithium-ion powered forklifts to the North American market... Continue reading
Joachim (Joe) Heel Joachim (Joe) Heel
Chief executive officer, Peak Technologies
Head of UK & Ireland, ROYPOW Global
Senior global sales manager, Lift-Tek
Senior manager sustainability, KION Group
September 10, 2026 - Covington, KY, United States
September 22-24, 2026 - Birmingham, United Kingdom
November 10-12, 2026 - Marina Bay Sands, Singapore
Africa is the only continent with land in all four hemispheres. The equator passes through seven African nations (the Democratic Republic of the Congo, Gabon, Kenya, Republic of Congo, São Tomé and Príncipe, Somalia, and Uganda), while the prime meridian crosses five (Algeria, Burkina Faso, Ghana, Mali, and Togo).
Unicarriers FHGE35T5S
Toyota 02-8FD25
