No start
Truck won't turn over has code 13
  • Posted 15 Jul 2018 04:03
  • By Weasel
  • joined 15 Jul'18 - 2 messages
  • Canada
I had similar issues, also sometimes error code 12 appears too. After check all my connections and finding out the lines were ok, I replaced the ECU and error code cleared out and equipment started.
  • Posted 11 Apr 2024 15:47
  • By Frank_Jacob
  • joined 3 Oct'23 - 17 messages
  • Nigeria
Hello , does anyone fix this error 13 in screen? It says nu communication , is it possible the Volvo engine Ecm damage? It have battery voltage on connector.
I have the same issue in a DCE 100 forklift , no start activation
regards
  • Posted 23 Jan 2024 02:26
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
well... hmmmm
either got a wrong or bad relay, put it in wrong place if they are different but have same plug socket, didnt plug in cables correctly or connected a wire to wrong place, damaged something in a connection... lots of possibilities here.
if you have access to diagnostic screen maybe check inputs and outputs , it may show you exactly where the problem is :o)
  • Posted 17 Jul 2018 00:35
Someone took start relays out and starter then replaced them now the edu screens shows a code of 13 witch says in book check the cable from com to the edu truck doesn't even turn over
  • Posted 16 Jul 2018 07:50
  • By Weasel
  • Canada
there should be more information other than 13 for the error code.
we need to know the node number it gives etc.
most of the codes i saw that have 13 all had to do with calibration but we need to know what needs calibration, the node number will determine this.
there is a big chance it is probably the accelerator but thats just a guess.
If you can get back to the truck and write down everything it shows when the error comes up that would be a huge help. ;o)
  • Posted 15 Jul 2018 21:53
