Toyota 8FGCU25:
No Start
I have this lift that runs great, and has no codes.
After running for awhile and turning it off it does not want to start up again.
Now after a few hours of sitting it will start and run great again.
  • Posted 19 Oct 2013 08:40
  • Discussion started by bowlerwa
  • Washington, United States
the regulator did have a leak that allowed a smell and a light hiss in the intake.
rebuild kit ordered.
thanks
  • Posted 30 Oct 2013 08:02
  • Reply by bowlerwa
I have observed that 8F models with 4Y engine develop a "long crank time" issue as the LP regulator ages. We have determined this to be caused by the secondary valve becoming leaky which will permit the primary fuel chamber to empty through the secondary valve while the engine is shut off. This effectively "floods" the engine and makes it necessary to crank the engine for a long time while holding the accelerator to the floor, or wait long enough for the engine to just clear itself (could be hours) after the primary chamber is fully depleted and the engine has vented the excessively rich mixture.
Sometimes you will be able to detect the smell of LP odorant at the intake air grille on the right side rear overhead guard pillar when the secondary valve is not seating.
  • Posted 29 Oct 2013 01:09
  • Reply by L1ftmech
  • Tennessee, United States
Will the unit start on either?
  • Posted 29 Oct 2013 00:13
  • Reply by bbforks
yep, does sound like it may be a gummed up regulator
try cleaning it first? before replacing that pricy component?
just a thought ;o)
  • Posted 26 Oct 2013 21:26
  • Reply by swoop223
I did check for spark and fuel.
I will probably change the regulator.
  • Posted 26 Oct 2013 08:01
  • Reply by bowlerwa
Sound like an ignition coil. I;ve had the same symptom on my Clarks. Check for spark from coil. I picked up this nifty spark checker that you don't have to disconnect the wire. You just lay it on the side of the wire while cranking the engine and it picks up the voltage.
  • Posted 24 Oct 2013 06:39
  • Reply by joe_d
Ain't nothing I can't fix but a broken heart and the break of day!
crank not start.
LPG
4Y engine
  • Posted 24 Oct 2013 02:43
  • Reply by bowlerwa
What are the symptoms when it won't start- won't crank, cranks but won't catch, etc? What engine's installed- what fuel is used?
  • Posted 19 Oct 2013 11:29
  • Reply by bbforks
ROYPOW
edition #1228 - 1 May 2025
