no start
I got this forklift in yesterday for a no start condition, its got compression ,spark ,I'm not sure if the regulator is working properly
it only pulses propane for a second then stops, It has started one time for a few seconds but idled very slow, then died when I gave it throttle. It has not started since. I have tried starter fluid, but nothing seems to help. Anybody ever ran into a problem like this? any help would be appreciated. Thanks
  • Posted 1 Mar 2016 09:24
  • By bruce864
  • joined 1 Mar'16 - 40 messages
no , no gauges yo check the pressures with, I ve gotten a new regulator and engine revolution switch for it. it just seems to not get enough fuel. I have back probed the pig tails on the regulator and they are working properly its just not getting enough fuel thru the hose to start.
  • Posted 6 Apr 2016 05:29
  • By bruce864
If you are sure the ignition system is working properly, it is usually a fuel delivery problem. Make sure the lockoff valve is opening, also check the inline fuel filter in the main feed hose. Do you have pressure test gauges for the LPG system?
  • Posted 3 Mar 2016 01:00
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Toyota 02-2TD20
UN Forklift FD35T
Libiao Robotics
