NO START
I HAVE A 2005 HYSTER H-XM (H177B57649C) HAD A OVERHEAT CONDITION WHEN DRIVER WENT TO ADD WATER WAS RUNNING AND JUST STOPPED ,I INSTALLED NEW RAD AND NOW CRANKS FOR A SEC THEN STOPS CRANKING IF I REMOVE COIL WIRE CRANKS FINE WITHOUT INTERRUPTION ANY IDEAS ?
  • Posted 9 Jun 2017 05:18
  • By Pro_Tech
  • joined 9 Jun'17 - 3 messages
Can you put a voltmeter on the starter solenoid and see if you are actually loosing voltage? I have not seen this problem.
  • Posted 13 Jun 2017 06:11
  • By BREWSKI
YES starter disengagement ,if i continue to hold in crank position will crank and stop like loosing power to crank relay i think it is in a safety mode ? just cant find any wiring issues yet if i remove secondary coil wire cranks without interruption
  • Posted 13 Jun 2017 03:03
  • By Pro_Tech
when you say it stops cranking does the starter just disengage? or does it stay engaged and stops spinning the engine like the engine is locking up? like a compression lock?
need to figure out if this is electrical or mechanical
  • Posted 12 Jun 2017 00:29
  • Modified 12 Jun 2017 00:30 by poster
IF I DISCONNECT THE COIL WIRE FROM THE DIST CAP IT CRANKS FINE WITH SPARK AND FUEL
  • Posted 10 Jun 2017 06:41
  • By Pro_Tech
Sounds like shorted wiring.
  • Posted 9 Jun 2017 22:26
  • By BREWSKI
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
May 14, 2026 - Blair Athol, South Australia, Australia
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
