No sparking and no LPG shutoff valve operation
Dear guys. I have a problem with a Forklift. This is a Mitsubishi FG25N , only LPG version. The problem is the following. The engine is cranking, but there is no spark on the spark plugs and no power on the LPG main valve. This is what I know and what I measured: There is 12V power supply on the ECU. On the ignition coils, there are the power supply, I think that the signal is missing for the timing. I checked the crankshaft and the camsaft sensor. They are working. When I try to start the engine, on the instrument panel I can see the working hours. When I stop it, it desapear. NO ERROR CODE. I have tried to figure out what can be the problem. I searched it on the wiring diagram. This is my opinion: From the ECU, there has to be 4 signal wire what go to the ignition coils. The cables are OK to there, no broken cable. Through those cabels the ecu has to give signals to the coils when to spark. I think that those signals are missing. I don't know why. I think, that for the timing, the ECU just need to recive the crankshaft sensor signal, but on the wiring diagramm, I saw an other part, what I dont know where can I find. There Is a "LOOP FOR THE IGNITION TIMING" Does anybody know wat is it? Maybe this is the problem. The LOOP is not working, that is why the computer doesn't give any signal to spark, and there is no signal to the main LPG valve also. Both system has separated outputs from the computer. I Am sure that some signal is missing, that is why there are no output signals on those pins. Any Idea what to check, or is there any Idea how is the ignition system working? What is that LOOP what is on the wiring diagramm?
  • Posted 26 Nov 2018 04:36
  • By banyacsky
  • joined 26 Nov'18 - 2 messages
  • Hungary
Hi My friend
How are you
I have problem with nissan-forklift MC01Z15 k15 engine.
My forklift dosent run but crank it.
I having quite the same problem same make and same Nissan engine lpg. The only thing in mine is that if i pulse manually the assist injector during cracking, it will start and if kept at half throttle for a minute , it will then run without any problems, and the assist injector works fine when the full throttle is applied, but not during cranking.
I am not sure if it needs to work during starting or will the ecm use the main injector to start.
I check relay box and relays and All fuse box its fine.
Just I replac Airflow meter becuse I have error e21 and after I Replac error code clear
I am an electrical technician and i repair other stuff for this client but this lifter was an extra, which will not accept another time.
Any help appreciated.
Please help me
Thanks.
Sent from my Huawei phone
  • Posted 9 Feb 2021 03:11
  • By Afshin_Ghafoori
  • joined 1 Feb'21 - 5 messages
  • Iran, Islamic Republic Of
Forgot to write: NISSAN K21 Engine in it
  • Posted 26 Nov 2018 04:43
  • By banyacsky
  • Hungary
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
Syrian port receives 16 new forklifts Latakia, Syrian Arab Republic
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Tusk 500PGH16
Ncn 110TH
Ncn 110TH 2015
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
