No Spark - won’t start
Hi everyone!! I have a C4000 Combilift s/n 4045 - with the GM 4 cylinder (cast iron head) that has no spark!! I have replaced the ignition coil and the ignition module to no avail. I have voltage at both the distributor & the coil. The rotor is turning when cranking, the leads test ok, cap & rotor look ok. This particular coil has two plugs that push in together to form a 4 pin plug. Negative side seems to test ok as does the 12v side. I'm wondering if maybe I have a distributor fault?
  • Posted 29 Jan 2024 20:28
  • By Mr_Pitt
  • joined 14 Feb'22 - 1 message
Mr Pitt
hi as i pointed out earlier it seems you have a break in the loom close to the distributer i would definitly be checking the wiring for a break i gather you have changed the distributer module? and placed any wires in the distributer in the correct place ie you havent shorted out any pos wires also make sure your engine has a good earth cable
although im sure richard from combi can help further
  • Posted 11 Oct 2024 19:15
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Hi,
Sorry to hear this is not yet resolved. As you are based in the Uk, and I don't have your contact details, can I get you to contact our Uk Technical team, via email on UK dot Services at Combilift dot com. I will send this chat onto them, so they will then be waiting for your email.
Hope you get this resolved
Thanks Richard
  • Posted 11 Oct 2024 03:42
  • Modified 14 Oct 2024 10:57 by administrator
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Hi Richard spoke with technical yesterday. We thought it was distributor but still no start. I have 12v to coil, new coil, new distributor and still no spark. It did start for a few seconds but stopped and again no spark. Pulling my hair out now.
  • Posted 11 Oct 2024 02:26
  • By Adrianret
  • joined 10 Oct'24 - 3 messages
  • United Kingdom
Hi Adrianret,
If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support. Anyone can request support for any age of truck.
Hope you get sorted.
  • Posted 10 Oct 2024 22:21
  • By Richard_Irwin
  • Monaghan, Ireland
Hi I have a similar problem mine has separate power supply to coil, running 7.5 amp fuse that blew. It's Been ok like thos for several years. The amps are around 5 to start with but after a few seconds it climbs to over 20 where tester maxs out. I've tried new coil and module on distributor. But still it dead shorts. I've tested wires to coil but no problem found. Can't find any diode. Help please
  • Posted 10 Oct 2024 01:27
  • By Adrianret
  • United Kingdom
Hi Mr Pitt. Great advice from Skyreach and Scott re the wires to from the distributor and to not only test for continuity but also ohm as there is a diode in one of these that may have failed. You might need to replace one of these.
You can also request access to our knowledgebase where you will find more information available. Hope you get sorted.
Combilift has a technical team in Australia and they will be more than happy to help you.
  • Posted 2 Feb 2024 21:16
  • By Richard_Irwin
  • Monaghan, Ireland
I haven't worked on many combe lifts but I might be able to help you first are you not getting spark to coil l would check the pick up coil inside the distributor there will be two wires ohm them out they should ohm between 500 and 900 ohms also give a light pull on them if they break that is your problem also undo them to ohm from module. If you need to change the distributor must be removed to install. hope l was of help.
  • Posted 2 Feb 2024 13:39
  • By Scott_
Scott
hi there i have had a similar problem with same unit exactly same fault changed numerous things unit would run and sometimes not start or cut out when running check the wiring at the distributor plug and by that i mean grab the wires and pull them see if the wire is broken inside if it is the wire will stretch the outer plastic if you see what i mean the wiring is sometimes wrapped in an s shape and its to tight our wire was broken close to the dist plug i managed to solder it back temp repair and ordered that harness section from combilift it is only a very short piece of loom hope thats your problem
  • Posted 30 Jan 2024 19:22
  • By skyreach
reach for the sky
Rail King RK330
Maxlion FD30
