No Power to the Platform But can raise platform from the Ground control
I Have a Skyjack SJiii 3219 s/n 262174 The issue i'm having with it is I have no power to the joystick Box. Did find a Bad Wire in the Harness to the platform. Replaced the Harness and a New Joystick Box. Still have no Power. But I Can use the Ground control to Raise the platform and Lower it. And the Batteries are showing Good. Don't Know what Else to look for Can some one Help. Thank's
  • Posted 10 Apr 2023 23:22
  • By Rat1
  • joined 6 Apr'19 - 12 messages
awesome Rat1
yep those pesky switchs ;o)
glad you got it back working
  • Posted 21 Apr 2023 07:24
Ok Got Back to Look at the Lift. Pulled out the Battery Charger to get to the switch and found that the push Button Was Bad. Order a New one and Installed it Now I Have Power to the Joy Stick. All is Working Good. Thank's For the Help.
  • Posted 21 Apr 2023 00:41
  • By Rat1
Here are skyjacks suggested possible causes for this issue:
if you need better detailed info go to their website and go to the manual section and download manual 'part number' 118941.
1. Loose or broken wire #07 from base terminal block
(TB-1) to platform emergency stop switch (S4).
2. Open or defective platform emergency stop switch
(S4).
3. Loose or broken wire #7A from platform emergency
stop switch (S4) to key switch (S3).
4. Open or defective key switch (S3).
5. Loose or broken wire #8 from keyswitch (S3) to battery
charge indicator (BCI).
6. Loose or broken wire #8 from platform keyswitch
(S3) to joystick enable switch (S7-6) (ANSI/CSA
only).
7. Defective joystick enable switch (S7-6).
8. Loose or broken wire #8 from battery charge indicator
(BCI) to LIFT/DRIVE select switch (S5)
(CE only).
9. Defective LIFT/DRIVE select switch (S5).
  • Posted 11 Apr 2023 10:09
JLG G12-55A
TCM FHD105Z
JLG G12-55A
TCM FHD105Z
JLG G12-55A
TCM FHD105Z
Sue Tomic Sue Tomic
