No lift, tilt or sideshift
Truck runs well, but does not lift, tilt or sideshift. The pump motor works and the switches seem to as well. The battery gauge does not appear to be working correctly and is low, but it should still sideshift and tilt. Any ideas?
  • Posted 25 Aug 2015 21:44
  • By forkmen123
  • joined 5 Jun'12 - 50 messages
Check the adjustment of the micro switch on the levers also check the switch for continuity they do cause this pronlem
  • Posted 26 Aug 2015 00:21
  • By lifter01
  • joined 4 Jul'09 - 463 messages
It appears to be an electrical problem. If I activate the contact by hand, then pull any lever, it lifts
  • Posted 25 Aug 2015 22:51
  • By forkmen123
If the pump motor is running you should have flow. my guess is you have a stuck relief valve or the pump coupling is broken.
  • Posted 25 Aug 2015 22:44
  • By BREWSKI
UN Forklift FL20-32LNJX2
Big Joe PDR30-154
USD7,500
GemOne
Big Joe PDR30-154
USD7,500
GemOne
