Yale GLC050VXNDAW083:
No lift code 523261-12
Code-523261-12 hydraulic interlock obviously no lift ,have tilt and sideshift working fine! Unit drives fine any help would be greatly appreciated
  • Posted 10 May 2023 01:05
  • Discussion started by LittleD
  • Virginia, United States
Switch the OPS solenoid between the tilt and lift to see if lift will work. Check to see if lift solenoid is getting hot, shorted. Not hot and switching does not work, wiring issue. Good Luck
  • Posted 27 May 2023 00:13
  • Reply by garland_m
Work Hard and Fish Long
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
