Unicarriers (& Nissan) CSP01L18S:
no Hyds
This unit has no hyds? the contractor does not close after start up? i have 10 volts at contractor coil, could this be the transistors or logic card or both thanks.
  • Posted 2 Jul 2015 03:40
  • Discussion started by Robrauch1971
rob rauch
Make sure you have full battery charge, and that the hydro control valve spool switches are adjusted as well. Being that you have a possibilty of several configuration of panels in the this unit, be a crap shoot on how to explain or troubleshoot as each panel are similar but different. Could be simple as in pump cut due to a low battery, spool switches, fuse, corrosion or expensive like a main print card.
  • Posted 13 Aug 2015 23:01
  • Reply by RCAV8TOR
  • Alabama, United States
edition #1234 - 12 June 2025
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
Your Focus
