No Hydraulics
Hydraulic wiring schematic Diag would be nice but here is the issue
No codes, Hyd motor, micro switches, contactor, battery and fuses all good
This unit has AC drive but DC Hyd with no visible controller , I have power to contacts and pull in coil , what controls the ground side on this ?
  • Posted 14 Jul 2015 21:51
  • By BrewCrew
We`re here for a good time
There is no ground on these trucks. The motor is supplied positive through a 325 amp fuse. You should have battery positive at the motor as soon as you plug in the battery. The pump contactor is in the negative side. You need to verify that you have negative at your contactor and at the motor terminal with the contact closed.
  • Posted 18 Jul 2015 02:16
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
November 3-4 2026 - Houston, United States
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
