no hydraulics after bad leak.
I was given an old Cat fork lift with a redseal 4 cyl engine that had not run in ten years. Someone painted it and covered up the placards. Pretty sure it is a V40C. the forks would only go up about half way and the steering was wierd, acts like it was low on fluid. Then the tilt blew a line and drained a LOT of fluid. Now mast only goes up about 3". I checked the fluid tank under the floor board on the right side and it is full. Is there another hydraulic tank??? even before the leak when the mast was going up about 1/2 way the tank did not seem to go down any and after the leak the tank level did not go down???
  • Posted 30 Dec 2023 10:25
  • By Bill_Biggs
  • joined 30 Dec'23 - 4 messages
web
Thanks, I will check all those tomorrow
  • Posted 31 Dec 2023 16:00
  • By Bill_Biggs
web
ok a few things i would check,
1) sure, check the filter and the check valve on it and also the sump filter/screen in the tank and the pickup tube.
2) pull the pump off and check the spline on the shaft.(might do this one last)
3) look on the hydraulic control valve, it has a relief valve located on one of the end housings, has a dome nut and another adjuster nut, pull that and make sure it is good, no broken springs or corrosion.
And then there is a priority valve inline between the control valve and the pump. That valve shuttles fluid between the hydraulics/steering, pull the spool and make sure it is not stuck or corroded.
also while checking those, look at the hoses, especially the suction side and make sure it is not collapsed.
  • Posted 31 Dec 2023 14:01
I also notice that there seems to be little or no flow (circulation) of fluid in the tank
  • Posted 31 Dec 2023 12:52
  • By Bill_Biggs
web
Yes it has a dip stick. I actually filled the tank to the top and still no go. I am leaning toward a clogged filter. Will try checking that tomorrow.
  • Posted 31 Dec 2023 12:50
  • By Bill_Biggs
web
no dipstick on the tank? should be one either on the cap itself or somewhere on the tank. I wouldn't trust just looking down into the tank through the hole.
it does sound like it is just low on fluid. One tell tell sign is when it stops lifting do you hear the hydraulic pump growling? it should be pretty obvious.
  • Posted 31 Dec 2023 08:42
Maxlion FB25LI
Mobicon 2T
Yale Lift Truck Technologies
