No hydraulic at times?
We just bought this unit
Randomly forklift loose full hydraulics No lift, No steer
There is no bad pump noises,
three SAS solenoids on valve body ok.
This truck has no seat switch,
any person seen this before/
S#60514
  • Posted 2 Feb 2023 04:47
  • By pacfork
  • joined 2 Jun'07 - 55 messages
  • British Columbia, Canada
This is just a guess when it happens install a pressure gauge in lift line or steer cylinder and see if you have no pressure it is possible the hyd pump shaft is worn or the gear inside the motor and it slips at times if no pressure pull pump and check spline it is splined to the motor gear. Hope this helps.
  • Posted 2 Feb 2023 14:40
  • By Scott_
  • joined 16 May'21 - 339 messages
Scott
edition #1285 - 11 June 2026
