---NO high speed ---
If you have no high speed on the pallet jacks check the horn switch. Just learned the high speed circuit is routed thru the horn circuit.
  • Posted 19 May 2015 03:26
  • By tomas_s
  • joined 24 Sep'10 - 60 messages
  • Bahamas, Bahamas
I have same problem it is not horn switch any ideas.
  • Posted 3 Sep 2015 05:26
  • By ZR7S
  • joined 17 Jan'14 - 5 messages
And the belly button switch goes through grab handle horn switch. If you have no emergency reverse on a 112, the horn switch is bad. They do this for freezers, where there is a plastic curtain you have to drive through. you hold horn to to go into plastic curtain. If the curtain hits the belly button switch, you dont stop and go into reverse, because the horn switch opens the circuit of the belly button or emergency reverse
  • Posted 28 May 2015 13:22
  • By EasiTek
Yep, Raymond thinks that if you can't beep your horn then you shouldn't be driving fast.
  • Posted 27 May 2015 10:00
  • By Mercanyin
  • joined 6 Sep'14 - 23 messages
  • Arizona, United States
edition #1281 - 14 May 2026
